NAT with official IP on DMZ
May 1st, 2007
Hello
I have a PIX 515E (Ver.6.3.1)with three interfaces. Now I d'like to activate the DMZ interface with a official IP-address range.
Between the internel and outside interface is a NAT (PAT) configuration active. No, I have problems to configure the NAT for the DMZ interface. With the official IP-adresses on the DMZ, it is not necessary to make NAT. I d'like to configure a simple routing between the internal to DMZ and between the ouside to DMZ.
How I is the NAT configuration for the a DMZ with official IP-adresse?
Pascal
Overall Rating: 4 (1 ratings)
Jon Marshall Tue, 05/01/2007 - 03:10
Hi Pascal
As an example lets say your DMZ addressing is
212.73.45.0/28
on your pix firewall
static (DMZ,outside) 212.73.45.0 212.73.45.0 netmask 255.255.255.240
As long as the ISP routes these addresses to your pix external interface you should have no problem.
Jon
