PIX 501 ISSUE
May 1st, 2007
Hi there,
had a very strange problem somedays back, and i'm wondering if anyone can help. Went to a client's site to replace a PIX 501 with and existing PIX 501, but for some reason, i was unable to estable reachability via ping on the internet. I regenerated the rsa key, recreated ssh, saved and reloaded my config, but i still had the same issue. please find the show run output of pix:
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname RLH-LANDMARK-pix
domain-name royallancaster.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name xxx.xxx.xxx.xxx LANZ-access
name xxx.xxx.xxx.xxx landmark-firewall
access-list 80 permit ip 192.168.100.0 255.255.255.0 host 192.168.1.153
access-list 80 permit ip 192.168.100.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list acom-traffic permit ip 192.168.100.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list acl-out permit icmp any any
pager lines 24
logging on
logging buffered alerts
mtu outside 1500
mtu inside 1500
ip address outside xxx.xx 255.255.255.128
ip address inside 192.168.100.254 255.255.192.0
ip audit info action alarm
ip audit attack action alarm
ip local pool micros-fidelios 192.168.100.253
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 80
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group acl-out in interface outside
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
crypto ipsec transform-set landmarkvpn esp-3des esp-md5-hmac
crypto ipsec transform-set vpnaccess esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set vpnaccess
crypto map vpnmap 1 ipsec-isakmp
crypto map vpnmap 1 match address acom-traffic
crypto map vpnmap 1 set peer landmark-firewall
crypto map vpnmap 1 set transform-set landmarkvpn
crypto map vpnmap 1 set security-association lifetime seconds 3600 kilobytes 24000
achalante Tue, 05/01/2007 - 03:20
second part:
crypto map vpnmap 10 ipsec-isakmp dynamic dynmap
crypto map vpnmap interface outside
isakmp enable outside
isakmp key ******** address landmark-firewall netmask 255.255.255.255
isakmp identity address
isakmp client configuration address-pool local micros-fidelios outside
isakmp nat-traversal 1500
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption 3des
isakmp policy 1 hash md5
isakmp policy 1 group 5
isakmp policy 1 lifetime 19200
isakmp policy 2 authentication pre-share
isakmp policy 2 encryption des
isakmp policy 2 hash md5
isakmp policy 2 group 2
isakmp policy 2 lifetime 86400
vpngroup micros-fidelios address-pool micros-fidelios
vpngroup micros-fidelios idle-time 1800
vpngroup micros-fidelios password ********
telnet 192.168.100.0 255.255.255.255 inside
telnet 192.168.100.178 255.255.255.255 inside
telnet 192.168.100.130 255.255.255.255 inside
telnet timeout 5
ssh LANZ-access 255.255.255.255 outside
ssh timeout 50
console timeout 0
vpdn group 1 accept dialin pptp
vpdn group 1 ppp authentication pap
vpdn group 1 ppp authentication chap
vpdn group 1 ppp authentication mschap
vpdn group 1 ppp encryption mppe auto
vpdn group 1 client configuration address local micros-fidelios
vpdn group 1 pptp echo 60
vpdn group 1 client authentication local
vpdn username micros-fidelios password *********
vpdn enable outside
terminal width 80
Cryptochecksum:xxx
: end
thanks in advance
acomiskey Wed, 05/02/2007 - 11:34
  • Green, 3000 points or more
Could you explain again what the problem is, I'm not sure what this means exactly.
" i was unable to estable reachability via ping on the internet"
Jon Marshall Wed, 05/02/2007 - 21:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Do you mean ping through to the internal network or ping to the outside interface of the pix.
If you are trying to ping the outside interface you need the following statement in your config
icmp permit any outside
You can tie down the IP addresses that are able to ping by replacing the any with individual IP addresses. Your outside access-list allowing ip to any will still not allow you to ping the outside interface of the pix.
If you are trying to ping through could you let us know the source and destination of the ping.
Jon
charan_jeetsingh Wed, 05/02/2007 - 23:37
one of the most imp things... have you checked with the ISP whether there is any static ARP entry for firewall on router...besides this i dont see anything wrong with the configuration.
