%error deleting cat4000bootflash permission denied
Answered Question
hello
I have 4507R i cant delete the vlan.dat from the cat4000bootflah i receive the following
how can i solv it?
10xs
Correct Answer by ankbhasi about 10 years 2 months ago
Hi Ali,
Can you please issue a command "dir cat4000_flash:" and confirm me if you only see vlan.dat file there?
If you see only vlan.dat file issue a command ""erase cat4000_flash:"
I believe there is nothing other than 'vlan.dat' file in cat4000_flash:, so that will take care of it. You may need to reload the switch to see the vlans disappear.
Ankur
Overall Rating: 5 (2 ratings)
Jon Marshall Tue, 05/01/2007 - 04:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Ali
What is the exact command you are typing in ?
Can you also post output of "dir" command on 4500.
Jon
mohammedmahmoud Tue, 05/01/2007 - 04:19
  • Green, 3000 points or more
Just guessing, what is the VTP mode of this switch?
BR,
Mohammed Mahmoud.
jamilakhtar Tue, 05/01/2007 - 07:06
Mohammed,
How would vtp domain would make a difference? just for peace of mind!!
Correct Answer
ankbhasi Tue, 05/01/2007 - 07:22
  • Cisco Employee,
Hi Ali,
Ankur
ankbhasi Wed, 05/02/2007 - 01:13
  • Cisco Employee,
Hi Ali,
The command "delete 4000catbootflash:vlan.dat" is a wrong command and there is no location like "4000catbootflash".
VLAN.dat on 4500 switches are stored in seperate location which is cat4000_flash so to delete this file you have to give exact location where file is stored.
Ankur
