Inserting a pause in a dial string
May 1st, 2007
Is it possible to insert a pause in a dial string using CCM 4.2? For example, on a voicemail speed dial a pause could be inserted after the VM extension and then a password could be automatically entered.
Thank you for the help
Overall Rating: 5 (1 ratings)
rob.huffman Tue, 05/01/2007 - 04:20
Hi Brian,
The "," (to add a 1 second pause)still only works on CME (BUMMER)
Telephone number to dialed. Represents a fully qualified E.164 number. Use a comma (,) to represent a one-second pause.
From this CME doc;
**For CCM it looks like Feature request/Bug CSCec41905 (ability to add pause in Speed dials) is still open :(
Hope this helps!
