IP Communicator Problems
May 1st, 2007
Have just installed IP Communicator onto Windows 2000 workstation but it doesn't load !!. I get a splash screen after running the audio tuning wizard andd there it hangs.
Does anybody have any ideas....please ?
scott.
mchandak Tue, 05/01/2007 - 05:36
  • Gold, 750 points or more
When you launch IP Communicator and get the slash screen, right click on the winow and select Preferences. Here, make sure that under Network Tab, you have the TFTP Server info updated
mchandak Tue, 05/01/2007 - 05:54
Can you run Error Reporting Tool and attach the output to this post ?
sdawson35 Tue, 05/01/2007 - 22:39
It doesn't get that far !!, I have a white box with a picture of a bloke using communicator on a laptop and thats it, it goes no further.
sheerazkhatri Tue, 05/01/2007 - 23:54
Check for any ACL on CCM VLAN... Make sure that your laptop passes through the ACL and can access CCM.
Sheeraz
sdawson35 Wed, 05/02/2007 - 01:54
This is from a desktop in my local lan - No ACL's apply
mchandak Wed, 05/02/2007 - 05:35
looks like we have missed couple of things,
Version of CIPC
Do you have Full Administrator rights on this machine ??
sdawson35 Wed, 05/02/2007 - 05:42
Version is 2.0.2
Yes local admin rights on Win2K workstaion in question.
Scott.
Zin.Karzazi Wed, 05/02/2007 - 05:43
  • Silver, 250 points or more
Go to your Eventviewer and post any error you are getting at the time when you run CIPC.
Zin.Karzazi Wed, 05/02/2007 - 06:13
Ok then run a sniffer (ethereal) see if CIPC is crashing before or after connecting to the Network.
