Problem calling to PSTN with MGCP gatway
Answered Question
May 1st, 2007
For some reason I cant call to an outside line. After dialing an outside line I hear the busy tone.
debug mgcp packets and debug mgcp error are giving me the following response:
*May 1 09:36:22.439: MGCP Packet received from 10.0.1.100:2427--->
CRCX 113 BRI/S0/SU2/P0/[email protected] MGCP 0.1
C: D000000001000040000000F50000000b
M: inactive
*May 1 09:36:22.439: Failed to create voice call leg, rc = -25!!!
*May 1 09:36:22.439: Following traceback is for INFO ONLY. -Traceback= 0x40A0E0A8 0x40A33EBC 0x40A27C8C 0x40A29BDC 0x40A0FE88 0x409D05CC 0x409D19A4 0x409D42C8 0x42110180 0x42110164
*May 1 09:36:22.439: MGCP Packet sent to 10.0.1.100:2427--->
400 113 Voice call setup failed-Incoming-Outgoing call collision
*May 1 09:36:23.455: MGCP Packet received from 10.0.1.100:2427--->
CRCX 10113 BRI/S0/SU2/P0/[email protected] MGCP 0.1
M: inactive
*May 1 09:36:23.459: Failed to create voice call leg, rc = -25!!!
*May 1 09:36:23.459: Following traceback is for INFO ONLY. -Traceback= 0x40A0E0A8 0x40A33EBC 0x40A27C8C 0x40A29BDC 0x40A0FE88 0x409D05CC 0x409D19A4 0x409D42C8 0x42110180 0x42110164
*May 1 09:36:23
VoiceGW#.459: MGCP Packet sent to 10.0.1.100:2427--->
400 10113 Voice call setup failed-Incoming-Outgoing call collision
*May 1 09:36:23.463: MGCP Packet received from 10.0.1.100:2427--->
DLCX 114 BRI/S0/SU2/P0/[email protected] MGCP 0.1
X: 1
S:
*May 1 09:36:23.463: MGCP Packet sent to 10.0.1.100:2427--->
250 114 already deleted connection
I use the following hardware:
MCS 7800 series Server with OS 2000.4.4aSR5
Callmanager 4.2(3)
Cisco 2851 ISR Router
- PVDM2-48 in slot 0
- VIC2-2BRI-NT/TE in HWIC 2
- VWIC-1MFT-E1 in HWIC 0 (not in use)
Anyone any idea's?
Correct Answer by philippgrafl about 9 years 11 months ago
BRI backhaul is not supported in 12.4 train on 2800 series. You need a 12.4T image.
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a0080541c9f.html
Overall Rating: 5 (1 ratings)
2044418Puts Tue, 05/01/2007 - 07:09
The gateway config is as follows:
Building configuration...
Current configuration : 4382 bytes
version 12.4
service password-encryption
hostname VoiceGW
version 12.4
hostname VoiceGW
boot-start-marker
boot system flash:/c2800nm-ipvoicek9-mz.124-13b.bin
boot-end-marker
enable secret xxx
no aaa new-model
clock timezone CET 1
clock summer-time CET recurring last Sun Mar 2:00 last Sun Oct 2:00 1
no network-clock-participate wic 0
network-clock-participate wic 2
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.1.1 10.0.1.50
ip dhcp excluded-address 10.0.10.1 10.0.10.50
ip dhcp excluded-address 10.0.11.1 10.0.11.50
ip dhcp excluded-address 10.0.20.1 10.0.20.50
ip dhcp excluded-address 10.0.21.1 10.0.21.50
ip dhcp pool Data
network 10.0.1.0 255.255.255.0
default-router 10.0.1.1
dns-server 195.85.130.161 195.35.128.5
ip dhcp pool DataBedrijf1
network 10.0.10.0 255.255.255.0
default-router 10.0.10.1
option 150 ip 10.0.1.100
ip dhcp pool VoiceBedrijf1
network 10.0.11.0 255.255.255.0
default-router 10.0.11.1
ip dhcp pool DataBedrijf2
network 10.0.20.0 255.255.255.0
default-router 10.0.20.1
ip dhcp pool VoiceBedrijf2
network 10.0.21.0 255.255.255.0
default-router 10.0.21.1
isdn switch-type basic-net3
voice-card 0
dspfarm
dsp services dspfarm
username ap password xxx
archive
path flash:/archive/$h
maximum 14
write-memory
time-period 1440
controller E1 0/0/0
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.0.1.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 10.0.10.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.11
encapsulation dot1Q 11
ip address 10.0.11.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 10.0.20.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.21
encapsulation dot1Q 21
ip address 10.0.21.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1
ip address dhcp hostname CCM
ip nat outside
duplex auto
speed auto
interface BRI0/2/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
interface BRI0/2/1
no ip address
ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
jconi Tue, 05/01/2007 - 11:53
Wait for Show ISDN Status, but depending on your provider, it's possible that the command "isdn static-tei 0" is missing under the interface BRI.
2044418Puts Tue, 05/01/2007 - 12:46
I'm using dynamic tei's. So thats not the problem. My ISDN interface is up and running.
Config Continued:
access-list 1 remark NAT
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 1 permit 10.0.10.0 0.0.0.255
access-list 1 permit 10.0.11.0 0.0.0.255
access-list 1 permit 10.0.20.0 0.0.0.255
access-list 1 permit 10.0.21.0 0.0.0.255
control-plane
voice-port 0/2/0
compand-type a-law
cptone NL
voice-port 0/2/1
compand-type a-law
cptone NL
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.0.1.100
ccm-manager config
mgcp
mgcp call-agent 10.0.1.100 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0.1
mgcp bind media source-interface GigabitEthernet0/0.1
mgcp profile default
dial-peer voice 20 pots
service mgcpapp
direct-inward-dial
dial-peer voice 21 pots
service mgcpapp
direct-inward-dial
gateway
timer receive-rtp 1200
banner exec ^C
You are logged on on $(hostname) via VTY $(line).
^C
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line vty 0 4
private
login local
terminal-type monitor
scheduler allocate 20000 1000
ntp update-calendar
ntp server 192.43.244.18
end
thisisshanky Tue, 05/01/2007 - 10:11
  • Purple, 4500 points or more
Can you paste a sh isdn status
2044418Puts Tue, 05/01/2007 - 12:49
I wont be at work till friday so I cant give you an exact show isdn status. But I can tell you that layer 2 is up and that layer 3 is under callmanager control. Thats what i remember since my last show isdn status.
And btw when there is a problem with my isdn interface, it wont register with CCM.
2044418Puts Tue, 05/01/2007 - 22:38
Could it be that I need to register the PVDM's in CCM?
Or does the gateway automatically use its local PVDM's like CCM Express?
ashraf1891 Sat, 05/05/2007 - 23:31
please can you post the runing configuration in your router ???
2044418Puts Sun, 05/06/2007 - 00:59
I already did....
The only thing I changed later on was the following:
service mgcpapp
direct-inward-dial
port 0/2/0 <------------- Added this line
service mgcpapp
direct-inward-dial
port 0/2/1 <------------- Added this line
