Can I use "Answer" softkey with 7911G?
May 1st, 2007
I define a phone-template below:
phone-template 2
softkeys hold Resume Newcall
softkeys idle Redial Newcall Cfwdall Dnd Pickup
softkeys seized Redial Endcall Pickup
softkeys alerting Endcall
softkeys connected Hold Endcall Trnsfer Park Confrn
softkeys ringing Answer Dnd
I apply the template to 7961/7941/7911. There is no problem with 61 and 41, but when pressing the "Answer" softkey to answer a call, the 7911 phones display "the key is not active here". Some documents describe that 7911 has a one-way speaker(listen mode only), is it true? Or the "Answer" softkey can not be used with one-way speaker?
Thanks!
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 05/01/2007 - 07:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Michael,
This debate comes up every once in a while. The determining factor for using the "Answer Softkey" with the Handset On Hook is whether or not the phone model has a speakerphone. If Yes then Answer Softkey is supported, if No (like the 7911,7912,7905) the the Answer Softkey with the Handset On Hook is not supported..
Hope this helps!
Rob
