Amit Singh Tue, 05/01/2007 - 08:05
That's a tough one. I dont think there is any command which will tell you the mfg date of the switch.
-amit singh
guruprasadr Wed, 05/02/2007 - 03:16
HI,
#show tech-support
Command will help you to see the entire Details of Switch.
Pls Rate if Helps ! !
compcruncher Wed, 05/09/2007 - 01:12
hi, sh tech-supp does not show any production dates ! only the software release dates und the uptime is shown here... the only hint is as earliery noted look at the chassistop - the yellow laser class product note shows the manufactured date e.g Jul 16 2002
that is if it is still there----
good hunting..
bud.nelson Wed, 05/09/2007 - 05:21
I was hoping to find something that works remotely. I don't have the luxury of having someone at all of the sites. I can approximate the ages using model and IOS release dates. etc. but the bean-counters are looking for real answers. Thanks all for your help.
