Pari Thiagasundaram Tue, 05/01/2007 - 08:07
  • Silver, 250 points or more
Using explorer, copy the IOS file from the folder to the root folder on the tftp server.
mohammedmahmoud Tue, 05/01/2007 - 08:22
  • Green, 3000 points or more
Hi there,
copy it to a folder on the PC, then from the solarwinds, go to file, then configure, then to the tftp root directory and point to the desired folder.
HTH, please rate if it does help,
Mohammed Mahmoud.
