valid hosts?
ankbhasi Tue, 05/01/2007 - 13:01
  • Cisco Employee,
Hi Ali,
Is this IP belongs to router interface or some workstations? Also can you update the subnetmask for these ip addresses?
Ankur
ankbhasi Tue, 05/01/2007 - 13:21
  • Cisco Employee,
Hi Ali,
I got a bit of hint from your previous post for EIGRP and with mask of 255.255.255.252 ip address 192.168.100.40 is not a valid address. 192.168.100.40 is the subnet address for its address block.
With subnet mask 255.255.255.252 valid address will only be 192.168.100.41 & 192.168.100.42
192.168.100.40 will be the subnet address and 192.168.100.43 will be the broadcast address.
Ankur
Amit Singh Wed, 05/02/2007 - 03:28
  • Cisco Employee,
Hi Ali,
I agree with Ankur on this.192.168.100.40 is not a valid host address, this is a subnet address. Valid IP's are .41 and .42 with .43 being the broadcast address for the subnet.
-amit singh
mohammedmahmoud Wed, 05/02/2007 - 04:02
  • Green, 3000 points or more
Hi Ali,
It depends upon the subnet mask.
Ex: 192.168.100.40/24 is a valid host, while 192.168.100.40/30 is not a valid host.
HTH, please rate if it does help,
Mohammed Mahmoud.
