Changing native VLAN
May 1st, 2007
Good afternoon,
I have two Catalyst 6506 switches running IOS version 12.2(18)SXF6 and have a trunk link between the two. One side is set to switchport and the other is a layer 3 interface with subinterfaces. I need to change the native vlan on the switchport side and need to know if I need to make any configuration changes on the layer 3 interface side? Also if and when I do change the native vlan on the switchport side will there be any major interruption of service to the trunk?
Amit Singh Tue, 05/01/2007 - 09:46
  • Cisco Employee,
To change the native vlan on the trunkport do the following:
conf t
interface gig x/y
switchport trunk native vlan X <- native vlan number
There will not be a major disruption of the service as such, you will get some error messages for " Native vlan mismatch " on the trunk ports untill both the sides are configured for the same vlan.
HTH,
-amit singh
