cat4000-i9s-mz.121-19.EW1.bin
Overall Rating: 5 (5 ratings)
Amit Singh Tue, 05/01/2007 - 09:51
  • Cisco Employee,
Hi Ali,
I would suggest to use SSO with NFS between the supervisor engines. SSO/NSF give you sub-milisecond fail-over between the sup's for both L2/L3 failover though we claim it around 0-3 seconds which depends on the traffic flow. My self has tested same with 900Mbps traffic and the failover time was arnd 300 milisecond.
You need atleaset 12.2.31SG for the same.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_31s/conf/nsfwsso.htm
HTH,
-amit singh
Amit Singh Wed, 05/02/2007 - 00:50
  • Cisco Employee,
Hi Ali,
This is the full image name that you need on the box :
cat4500-ipbase-mz
HTH,
-amit singh
