advertisment Network in EIGRP
Overall Rating: 5 (2 ratings)
sundar.palaniappan Tue, 05/01/2007 - 11:04
  • Green, 3000 points or more
Ali,
Your configuration is correct and it should work fine. Alternatively, you can configure the network statement with a wild card mask of all 0's as shown below and this would avoid any problems arising out of wild card mask miscalculation.
R1
router eigrp 1
network 192.168.100.41 0.0.0.0
no auto-sumary
R2
router eigrp 1
network 192.168.100.42 0.0.0.0
no auto-sumary
Sundar
sundar.palaniappan Tue, 05/01/2007 - 11:28
Sure, let's take your configuration and add another interface as shown below but you want to run EIGRP only on the first portchannel interface. Let's say someone fat fingered the network statement with a wild card mask of '0.0.0.255' then you would end up enabling EIGRP on both interfaces.
R1
int Potchannel1
ip address 192.168.100.41 255.255.255.252
int portchannel2
ip add 192.168.100.45 255.255.255.252
R1
router eigrp 1
network 192.168.100.40 0.0.0.255
no auto-sumary
All you are doing with the network statement is enabling EIGRP on an interface and if using a mask of all 0's would do it then why sit there and calculate the wild card mask unnecessarily. Moreover, keeping things simple where you can isn't a bad strategy at all :-)
Sundar
