Joe Clarke Tue, 05/01/2007 - 11:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of CiscoWorks? How are you trying to add it? The CiscoWorks LMS/CSM/OM SSO is not compatible with the WLSE.
Joe Clarke Tue, 05/01/2007 - 11:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The WLSE is supported by RME. You can add the WLSE to DCR as a Standard device, and RME will manage it. As for SSO, this will not work between LMS and the WLSE.
rice.randy Tue, 05/01/2007 - 11:51
Any clues as to when SSO might be supported in WLSE?
Joe Clarke Tue, 05/01/2007 - 11:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is not planned as the WLSE does not use Common Services.
rice.randy Tue, 05/01/2007 - 11:43
Sorri, forgot to add that I have added it as application under Common services,Home PageAdmin
Joe Clarke Tue, 05/01/2007 - 11:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can add the WLSE as a link on the CiscoWorks Homepage, but you cannot use the LMS SSO authentication mechanism to authenticate to the WLSE.
