jreekers Tue, 05/01/2007 - 14:10
A "show ver" should give you that (as long as it's running IOS).
mgracias Wed, 05/02/2007 - 15:17
How can i login into the AP(LWAP).It is not allowing me to telnet.Is there any way i can login into the AP.
leon.mflai Thu, 05/03/2007 - 08:39
For LWAPP AP 1230 and 1240 version, you can login to the AP via Console cable.
zhenningx Mon, 05/14/2007 - 06:55
In WCS, select the AP, and select "UP Time" in the "select a report" list.
Zhenning
ericgarnel Tue, 05/15/2007 - 10:03
For the lwapp based APs (10x0) series, you can run the controller in L3 mode and have the APs pull ip addresses. As of 4.1.x, they are now pingable.
You can then change them from dhcp to static ips and then use a monitoring tool such as Cacti or nagios to monitor them.
With a mesh, it is theoretically possible to monitor ping latency to each mesh AP and then that as a guide to determine if the pole top APs have switched to a root that more hops away: assuming that more hops would result in increased latency. Many NMS systems can kick back uptime based on icmp results
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
