2FXS module on 1760
May 1st, 2007
I have a 1760 at our remote mfg facility. We are connected via a p2p T1. In the 1760 installed are a 1DSU T1, 2FXS, and 4FXO modules. The 2FXS is slot 2, and port 1 is connected to an overhead night-ringer.
The port is part of a pickup groug that every call to the facility should cause the night-ringer to activate. This does not happen.
I've tested the ringer unit itself and it does work. The status light on the 2FXS module is green. When a call is placed to the pickup group the port light does not illuminate.
What might be a cause, or where do I troubleshoot from here?
paolo bevilacqua Tue, 05/01/2007 - 12:53
  • Hall of Fame,
    Founding Member
are you using CM? if so with which protocol? is the port getting the call? That is, when you connect a phone to the fxs, does it ring ?
benharned Tue, 05/01/2007 - 13:39
Yes, I'm running 4.2(3) CCM. I'm not sure what you mean by protocol... And I am unsure if the port is getting the call.
Since the router is at a different location, I will go there tomorrow and test it.
benharned Wed, 05/02/2007 - 11:01
Plugging in a phone i do get dial tone and am able to dial out. Dialing in gets nothing, no ring. This leads me to believe it's a pickup group issue. Seem right?
Any other suggestions?
paolo bevilacqua Wed, 05/02/2007 - 12:03
  • Hall of Fame,
    Founding Member
Please post in "IP telephony" with a title like "CCM pickup group for FXS port". You will need to specify CCM version and if you are using H.323, MGCP, or SCCP to the GW.
