Checkpoint vpn trough cisco 877
May 1st, 2007
Hi all,
I have a ADSL Line/Modem, connected to a PC, and gives me a good internet connection.
I have installed in my PC a vpn software, "CheckPoint Secure Client", that i use to connect to the establish a vpn tunnel to my company checkpoint Firewall, giving me Job Resources.
Now i bought a ADSL Router, Cisco 877, wich have 4 Switch port's more.
I configured the router to various LAN users access the internet, with NAT overload (PAT), wich works fine.
When i tried to connect to my work with vpn software, i couln't establish the connection, saying that i could not connect to the VPN Gateway.
I perform a ping to the public ip, that i use to establish the connection, and the CheckPoint guy, says that im reaching the site.
I dont know what is wrong, since if i change it all to the first solution, PC - ADSL - Internet - CheckPoint, the connection is established.
This is the scenario i perform, and the attached the router configuration.
[PC 1] ----- [Cisco877] ----- [Internet] ----- [CheckPoint FW]
[PC 2] ----------|
The Router, should not perform any kind of vpn issues, rigth ?
its only a hub in the tunnel?, or should i config something more?
What kind of debug should i perform ?
Best Regards,
Petr?nio
