Issue with upgrading 3750 IOS feature-set via LMS/RME
Answered Question
May 1st, 2007
Hello.
Has anyone experienced any issues with upgrading the feature-set of 3750s from ipbase to ipservices (same version)?
There is the '/allow-feature-upgrade' option via cli but not on RME. Is this even supported on LMS?
Thx.
Correct Answer by Joe Clarke about 9 years 10 months ago
I didn't see a service request opened for this yet, and now that I have my lab back I was able to write some code and test this. I have filed CSCsi74369 to track this problem. If you open a service request, a test patch can be made available that should fix this problem.
Overall Rating: 4.5 (2 ratings)
Joe Clarke Tue, 05/01/2007 - 16:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, RME can do this provided you have not checked the "Include same image feature subset as running image." box under RME > Admin > Software Mgmt > View/Edit Preferences.
dlongworth Tue, 05/01/2007 - 17:11
Thanks for the reply Joe.
This option is not checked.
This is the error message from the telnet log;
'Error: The image in the archive which would be used to upgrade system number 1 does not support the same feature set.'
Also the log shows;
'archive download-sw /overwrite tftp://...'
but not '/allow-feature-upgrade'.
This is upgrade from c3750-ipbasek9-mz.122-35.SE1 to c3750-ipservicesk9-mz.122-35.SE1
Joe Clarke Tue, 05/01/2007 - 19:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
How is this switch configured (i.e. is it in a stack configuration)?
dlongworth Tue, 05/01/2007 - 20:04
Default single switch (c3750-48PS), straight out of box. Just got an ip-address, snmp, etc for basic management.
We're testing before a major deployment. I was gonna log a call but thought I'd check here first.
Joe Clarke Tue, 05/01/2007 - 20:19
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Our lab is down, so I can't test for certain, but it looks like the ability to upgrade across feature sets changed in 12.2(35)SE code. That's when this "/allow-feature-upgrade" flag was introduced. Prior to that, things just worked. A bug will most likely be required here.
dlongworth Tue, 05/01/2007 - 20:25
So are you saying I should go ahead and log a call with TAC or is that something you can initiate internally?
Joe Clarke Tue, 05/01/2007 - 20:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Since I cannot do any further analysis right now, and since a bug will most likely be required, you should definitely open a TAC service request.
When you do, include the swim_debug.log as well as the job directory showing the problem. This should be very easy to reproduce.
Correct Answer
Joe Clarke Wed, 05/02/2007 - 14:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
dlongworth Wed, 05/02/2007 - 15:55
Thx again Joe.
I've got to go through our TAC first, but it's in progress.
