jeff.teoch Wed, 05/02/2007 - 01:26
Looking at the errors, it could be two reasons.
1. The speed and duplex mismatch in between the switchport and the end device.
2. The media of gigabit connection (physical) is faulty or not compatible.
Jeff
join_sn09 Thu, 05/03/2007 - 00:45
Dear jeff,
Thak you for your email.i'm going to check this problem again.
I will let you know.
Best Regards,
Join
Anand Narayana Thu, 05/03/2007 - 00:48
is this happening while connecting on that particular port or even if you connect on other ports also.
check the cable termination, even the cable which is connecting from the end device might be damaged.
