Router(boot)# ?
May 1st, 2007
A 2501 router isn displaying (boot)> after the hostname. The copy command is not recognized by the router, ie "copy tftp flash" does not work. Can someone assist me in getting this router to work. The following is the output of the show ver output.
Thanks.
Router(boot)#sh ver
IOS (tm) 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFTWA
RE (fc1)
Copyright (c) 1986-1996 by cisco Systems, Inc.
Compiled Fri 27-Dec-96 17:33 by loreilly
Image text-base: 0x01010000, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
Router uptime is 5 minutes
System restarted by power-on
Running default software
cisco 2500 (68030) processor (revision N) with 6144K/2048K bytes of memory.
Processor board ID 06160672, with hardware revision 00000000
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
1 Ethernet/IEEE 802.3 interface.
2 Serial network interfaces.
32K bytes of non-volatile configuration memory.
Configuration register is 0x2142
Overall Rating: 4 (1 ratings)
Danilo Dy Tue, 05/01/2007 - 17:58
  • Blue, 1500 points or more
Your router boot from the boot image not IOS image.
You need to upload the IOS image or if you have an existing IOS image in your router flash, you need to instruct the router to boot from it.
About the copy tftp flash not working, that strange but I will look into it and let you know.
In the meantime try the instructions in this link http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a0080110ed1.shtml
saidfrh Tue, 05/01/2007 - 18:15
Thanks for the link. The TFTP server is reachable using ping. The "copy" command is not recognized. The router does not accept copt tftp flash command.
RouterB(boot)#config t
Enter configuration commands, one per line. End with CNTL/Z.
RouterB(boot)(config)#int e0
RouterB(boot)(config-if)#ip address 172.16.10.1 255.255.255.0
RouterB(boot)(config-if)#no shut
RouterB(boot)(config-if)#end
RouterB(boot)#
%SYS-5-CONFIG_I: Configured from console by console
RouterB(boot)#ping 172.16.10.2
Sending 5, 100-byte ICMP Echos to 172.16.10.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/203/1000 ms
RouterB(boot)#copy tftp flash
% Invalid input detected at '^' marker.
RouterB(boot)(config)#copy tftp flash
Danilo Dy Tue, 05/01/2007 - 18:32
The error message means something not right in your syntax.
Which of the syntax the ^ is pointing? tftp or flash?
You may need to use ? to get the correct syntax after copy
Richard Burts Tue, 05/01/2007 - 19:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Said also posted a question about this in the Getting Started forum. I posted an answer in that forum suggesting the tftpdnld command. Have you had an opportunity to try that command?
The config register value as displayed in the show version command is 0x2142. The final 2 instructs the router to look in the config in NVRAM for boot system commands. But the 4 in the config register instructs the router to ignore the config file in NVRAM. It might be useful to set the config register to 0x2102 and try to boot again.
It might also be helpful if Said could capture and post the console output when the router attempts to boot. This might give us better insight into what is happening when the router attempts to boot.
Rick
saidfrh Tue, 05/01/2007 - 19:33
Rick,
I changed the config-register to 0x2102. Results of your suggestion:
RouterB(boot)#tftpdnld ?
% Unrecognized command
The following is the output after a cold start, help options and sh ver output.
2500 processor with 6144 Kbytes of main memory
Loading cisco2-2500 ... [timed out]
File read failed -- Time out
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
RE (fc1)
RouterB(boot)#?
clear
clock
debug
no
exit
logout
lock
show
terminal
test
undebug
disconnect
name-connection
resume
where
configure
disable
enable
ping
systat
traceroute
write
copy
login
reload
send
setup
telnet
rsh
connect
tunnel
slip
ppp
bfe
pad
x3
start-chat
help
RE (fc1)
RouterB uptime is 7 minutes
Anand Narayana Tue, 05/01/2007 - 22:41
  • Silver, 250 points or more
ur IOS is corrupted, jus re-install the IOS, your problem will get solved.
hope this helps.
rate this post if satisfied.
mohammedmahmoud Tue, 05/01/2007 - 23:18
  • Green, 3000 points or more
Hi Said,
As Rick said, try tftpdnld and then xmodem (both are done from rommon not boot image):
?Console download (xmodem)?Use this method if the computer that is attached to your console has a terminal emulator that supports the Xmodem Protocol. See the "Downloading Files over the Router Console Port (xmodem)" section.
For more information about using the Xmodem protocol, see the Xmodem Console Download Procedure Using ROMmon at the following URL:
http://www.cisco.com/warp/public/130/xmodem_generic.html
?TFTP download (tftpdnld)?Use this method if you can connect a TFTP server directly to the fixed LAN port on your router. See the "Recovering the System Image (tftpdnld)" section.
Note Recovering the system image is different from upgrading the system image. You need to recover the system image if it becomes corrupt or if it is deleted because of a disaster that affects the memory device severely enough to require deleting all data on the memory device in order to load a system image.
http://www.cisco.com/en/US/products/ps5854/prod_configuration_guide09186a00802c35e9.html
HTH, please rate if it does help,
Mohammed Mahmoud.
