VPN Conentrator 3005 Console/Admin
May 1st, 2007
I need help!! I cannot connect to my console port via HyperTerm. I have all the settings per the doc: 8-N-1-Hardware. I've been able to connect to another 3005 with the same cable. The reason I need to connect it is to perform an Admin reset as I do not have full authorization via Concentrator Manager or menus. Please HELP!!
Scott
adgzer0106 Wed, 06/27/2007 - 05:02
hi,
Did you ever get round this? As I have exactly the same problem.
Cheers
Andy
skumpf Wed, 06/27/2007 - 05:22
Yes we did. Actually, it came down to having the appropriate console cable. As there are many different Cisco console cables not all have the same pin-out. Unfortunatley I was not on-site and had to depend on a Technician to verify the actuall cable type. There is a specific cable to the VPN concentrators. A switch or router console cable will not work.
Hope this helps. Good Luck,
