WLC 2106 CPU ACL Preventing Client from Getting DHCP traffic
May 1st, 2007
Here is my portion of ACL List applied on the Controller CPU.
- permit UDP DHCPServer DHCPCLient Any Outbound
- Permit UDP
DHCPClient DHCPServer Any Inbound
The DHCP server is connected to a Cisco Switch on different VLAN.
When I enable the CPU ACL. The client couldn't get any IP address.
But when I disable the CPU ACL. the clients have no problem getting the IP Address.
what could be wrong here?many thanks
Overall Rating: 5 (1 ratings)
jwadleigh Fri, 08/24/2007 - 12:57
If your DHCP server is on a different subnet than your clients, then you'll have to set up a helper address so that clients can cross L3 to reach the DHCP server.
Apply the following command to the router interface facing the client:
ip helper-address
