Remote Access Cisco 877 IP issue
May 1st, 2007
I have set up remote access using a cisco 877 and the Cisco VPN client which is working fine but I have a strange IP issue. The remotes are unable to ping an internal address unless the address has been issued on the private network by DHCP, with one exception. The internal server has a static address and this can be reached by the remotes but any other static address cannot. Any help would be greatly appreciated. John
mohammedmahmoud Mon, 05/07/2007 - 22:25
  • Green, 3000 points or more
This issue might be related to the NATing done on your 877, which NATs only this range of LAN IPs which are reachable.
HTH, please do rate all helpful posts,
Mohammed Mahmoud.
sdesteuben Mon, 07/02/2007 - 19:21
post your clean running so we can have a look. moh. prob right. you might be nat'n it by mistake.
