1721 MEMORY UPGRADE
May 1st, 2007
Dear ,
Is it possible to add 64 MB memory module with the exisiting 64 MB module.
Or how can i do the memory upgrade
In cisco dynamic configurator, 128 memory module support is given.
I want to go for the 64 x2 option.
It is possible
Thanks in Advance
swami
CSCO10892433 Wed, 05/02/2007 - 00:35
  • Silver, 250 points or more
Hi, arumuqasamy
Actually, 1721 has one built-in 64MB memory, that means even the dimm slot is empty , you got 64MB memory. Get another 64MB memory and insatall it to the dimm slot, then you will have 128MB memory in total.
SSLIN
