Help with multidirectory.asp problem
May 2nd, 2007
I've recently installed multidirectory.asp and am attempting to point to 2 clusters running DC Directory.
I created a new service and from an IPC subscribed to the service, I get the
1) All Directory Sear
2) Cluster-1 Directory
3) Cluster-3 Directory
When I select either of the directories, I am taken to the Search criteria page, then when I press submit (either specific or blank) Requesting flashes at the bottom of the screen, then the search page is returned again.
Any ideas? I'm running CCM 4.2(3)
Joe
alan_joseph Wed, 05/02/2007 - 00:47
I've also tried this on a CCM 4.1(3) Cluster with a 7960 with the same results ~ Could it be a problem with the LdapUserId & LDAP Password?
I'm using the multidirectory.asp right out of the box as it comes with the 4.1.1 SDK, and the only thing I changed was the LdapServer (tried IP Address & Hostname) ... These are development servers, so I'm still using the default DC Directory login & Password of "directory manager" and "cisco"
I've tried using a separate user under cisco.co users thought that doesn't want to work either ...
SEBASTIAN SIEBRASSE Thu, 05/03/2007 - 08:04
We've found different models of phones parse the javascript code differently:
With our setup ccm4.1(3) & 4.? SDK, 7940/7960s work fine with multidirectory whereas 7912s fail as their asp/xml handling isn't as full as the 7940/7960s (so we slightly amended the script so its only run on 7940/7960 whereas anything else uses the standard xmldirectory.asp on the ccm; nb we even had issues with the 7912s understanding that redirect code which was fixed by upgrading their firmware.)
7941Gs also don't work as they handle the code differently (argh!) Trying to work around that now.
For diagnosis worth looking at the IIS webserver logs where the SDK was installed.
Only thing we changed in multidirectory was , & .
Seb
(ps anyone know I how I change my forum display name?!)
