05-02-2007 12:17 AM - edited 03-11-2019 03:08 AM
I have 1 problem in configuration which normally worked on PIX 6.3(1) but showing Warning message during implementation on ASA.
I have 2 statics:
static (dmz,outside) tcp XXX.XXX.XXX.XXX 8080 YYY.YYY.YYY.YYY 8080 netmask 255.255.255.255 0 0
static (inside,outside) tcp XXX.XXX.XXX.XXX https ZZZ.ZZZ.ZZZ.ZZZ https netmask 255.255.255.255 0 0
Public ip XXX.XXX.XXX.XXX is the same, private ips in inside and dmz is different
The second static ASA not allowing me to enter: Warning: conflict with previous static
On Pix 515 v.6.3(1) this configuration worked very well.
Is there any trick to start this work??
Thanks. Alex
05-02-2007 04:45 AM
Do you have another static with ZZZ.ZZZ.ZZZ.ZZZ?
05-02-2007 04:53 AM
ZZZ.ZZZ.ZZZ.ZZZZ is internal ip, there is no any other static configured for it.
Error showing problem of XXX.XXX.XXX.XXX IP address conflict
