IP phone features and IP telephoney hardware usage discription!
May 2nd, 2007
Hello everyone!
i would like it if someone can explain to me what the following features of IP Phones:
1)support for multiple telephone lines
2)Dynamic soft keys.
for example the cisco 7970G phone supports 8 dynamic soft keys and 8 lines. what does it mean?
the other thing is what is the functionality of each of the following hardware components in a 3845 ISR in a unified network :
1)VIC2-4FXO
2)VWIC-1MFT-E1
please give me the detail as soon as possible. many thanks in advance.
rodmont74 Wed, 05/02/2007 - 09:56
Hello Sherlock, hope is all well. Let me see if I can help you a bit. Dymanic keys means they are set in a context and they are programable by Sysadmin. The dyn keys are the ones in your IP phone just bellow or at the side of the LCD. As for the lines, I am not sure but I believe you could attach 2 or more (8 in 7970G) different extensions to the phone.
The cards you mentioned look like respectivatelly, a 4 port FXO one and a E1 controller (which might have one o more E1 ports).
Someone can confirm that please?
