NIST Net WAN Emulation Software does not work correctly
May 2nd, 2007
  • Bronze, 100 points or more
Hi everyone,
I downloaded NIST Net WAN Emulation Software below from CCO (http://www.cisco.com/cgi-bin/tablebuild.pl/fe_util).
to measure WAAS performance in our lab.
Cisco-NISTnet3-disc1-v4.iso
NIST Net ISO, kernel 2.6.9-22. Added support of GigE and other HW. 4.0
And I installed NIST Net WAN Emulation Software into brand new DELL PowerEdge 1950 according to
the following document.
NIST Net WAN Emulation Software Installation and Configuration Note
http://www.cisco.com/en/US/partner/products/ps6469/products_installation_and_configuration_guide09186a00804965e0.html
Installation has finished successfully but NIST Net does not work correctly with the following message
displayed continuously.
fast_rtc: lost around 26 interrupts at 8192Hz
or
fast_rtc: lost around 0 interrupts at 8192Hz
Why there is a differentiation as 26 or 0 is that it seems to depend select entry on the menu
that displayed by executing "./nistnet" command.
And I have to execute system restart (CNTL + ALT + DEL) to stop the message from being displayed
continuously.
I can not resolve this problem, so would you please let me know how I can resolve it to get NIST Net
work properly.
Your information would be appreciated.
Best regards,
mmellet Tue, 05/08/2007 - 05:57
The only workaround available currently is what you have done " Reloading the Device "
snakayama Tue, 05/08/2007 - 16:54
Thank you very much for your reply.
I understand it.
Hi snakayama,
I too downloaded the Cisco-NISTnet3-disc1-v4 and extract it into an CD.  But is there any other steps i need to do??
Coz when i boot the CD, it doesn't boot.
Do i need to put certain files into specific location?? Or is there any speical instruction i need to do??
Would appreciated any help on this as i have spent hours on this but it still couldn't boot up.
Cheers,
Hunt
snakayama Sun, 05/30/2010 - 19:01
Hi Hunt,
Unfortunately I wouldn't be able to answer your question clearly but I would like you to give the information that might help you.
NIST NET Home Page
http://www-x.antd.nist.gov/nistnet/index.html
How to install the  emulation package, version 2.0.12
http://www-x.antd.nist.gov/nistnet/install.html
(It is for version 2.0.12 not 4.0, however I think the basic procedure might be the same ...)
I hope this information help you.
Shinichi
