WAE 512 and transaction logs problem
Hi guys,
I have a WAE 512 with ACNS 5.5.1b7 and I'm not able to export archived logs correctly. I tried to configure the WAE as below:
transaction-logs enable
transaction-logs archive interval every-day at 23:00
transaction-logs export enable
transaction-logs export interval every-day at 23:30
transaction-logs export ftp-server cache **** .
and the WAE exported only one file of about 9 MB even if the files was stored on the WAE as you can see from the output:
Transaction log configuration:
Logging is enabled.
End user identity is visible.
File markers are disabled.
Archive interval: every-day at 23:00 local time
Maximum size of archive file: 2000000 KB
Log File format is squid.
Windows domain is not logged with the authenticated username
Exporting files to ftp servers is enabled.
File compression is disabled.
Export interval: every-day at 23:30 local time
server type username directory ftp cache .
HTTP Caching Proxy logging to remote syslog host is disabled.
Remote syslog host is not configured.
Facility is the default "*" which is "user".
Log HTTP request authentication failures with auth server to remote syslog host.
HTTP Caching Proxy Transaction Log File Info
Working Log file - size : 96677381
Archive Log file - celog_213.175.3.19_20070420_210000.txt size: 125899771
Archive Log file - celog_213.175.3.19_20070422_210000.txt size: 298115568
Archive Log file - celog_213.175.3.19_20070421_210000.txt size: 111721404
I made a test and I configured the archiveng every hour from 12:00 to 15:00 and the export at 15:10, the file trasnferred by the WAE was only three one of 12:00 the other of 13:00 and 14:00 the 15:00 has been missed.
What can I do?
joquesada Thu, 05/03/2007 - 04:26
Hi Davide,
You seem to be missing the path on the FTP server; which goes on the export command.
Disable transaction logs, then remove the export command and then add it again like this: transaction-logs export ftp-server cache **** / ; after that enable transaction logs again and test it.
Let me know how it goes. Thanks!
Jose Quesada.
Hi Jose,
I don't think that the problem is the path because I didn't receive any file, instead I receive in one case a file of 9 Mb and the other case three files.
I opened a case on this topic and the engineer wrote me that there are some bugs related to this topic and his suggestion is to upgrade the release to the 5.5.5b4.
