ATM module & part number
May 2nd, 2007
I have some module's name to check.
From some LS1010, I have the shart-number (from the sh hardware).
Can someone give me a link or a file to get the name of the module ?
ex: 73-1496-03 for WAI-OC3-4MM I guess
I have others part number to find like: 73-1402-04
73-1572-03
73-1497-02
68-0651-01
73-1864-03
and some others
Overall Rating: 4.5 (2 ratings)
Paolo Bevilacqua Wed, 05/02/2007 - 08:07
I don't have an LS1010 to test, but I remember that some "show diag" or similar command, would list you the modules product codes as well.
Hope this help, please rat post if it does!
jabouaf Wed, 05/02/2007 - 22:20
Hello Paolo,
I think that on LS1010 only the "sh hardware" command gives us some part of information as serial number, part-number and small description as
155PM, 155UTP, ASP, FC (feature card -a dauther one on the ASP), but I quit remenber there is several ASP card model with several FC. And I'm not sur of what I have. -and so I'm cheking-)
Maybe serial number can help me much.
I'm going on this way.
Thank you for answering.
Best regards,
Paolo Bevilacqua Thu, 05/03/2007 - 03:35
Yes, there is more than one ASP, but I remember that based on the output it is possible to tell what type of ASP was installed.
Thanks for the nice rating and good luck!
