Configuring HSRP on a CISCO 2800 router
Answered Question
May 2nd, 2007
Good Day,
Could you please guide me how to configure HSRP between two CISCO 2800 series routers? How many switches are required for the effective implementaion of HSRP? Is there any neccesity to do HSRP configurations on the ISP side router? Please do guide me with your professional advice.
Thanking you in anticipation,
Sam
Correct Answer by Amit Singh about 10 years 2 months ago
Sam,
You need only a single switch to connect to routers with the LAN ports on this switch. HSRP is used for Gateway redundancy for your LAN hosts. It is not implemented on the WAN/ISP side.
Please see the link below for HSRP configuration:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008042fbb3.html
HTH,please rate if it does.
-amit singh
Overall Rating: 5 (1 ratings)
Correct Answer
Amit Singh Wed, 05/02/2007 - 03:32
  • Cisco Employee,
Sam,
-amit singh
rumhyvarghese Wed, 05/02/2007 - 03:38
Good Day Sir,
Your response was very helpful.
Once again I thank you for the effort done.
Best Regards,
Sam Varghese
