IP overlap with VPN client
May 2nd, 2007
I need to connect to resources on a remote 10.1.1.0/24 network via VPN client. My internal net is also 10.1.1.0/24. What do I need to configure on the remote PIX to allow this?
Thx,
Phil
acomiskey Tue, 05/08/2007 - 08:40
  • Green, 3000 points or more
When you connect to the vpn you will get an address in the vpn client pool which needs to be set to a different subnet. Other than that you should not have problems.
