Warning message when trying to delete NAT on ASA 5520-K8 (ADSM 7.1(2)
May 2nd, 2007
I am trying to delete a Static NAT that I have created in error, but when I click 'delete' from the 'configuration>NAT>Translation Rules' tab, I get the following error:
The operation you are trying to perform will result in some security rules being nullified. Please review your translation/security rules and try this operation again.
Anybody got any ideas how I can delete the NAT?
Scott.
Overall Rating: 4 (1 ratings)
aeljabari Wed, 05/02/2007 - 09:50
HI Scott,
I believe that you have to delete or modify any access list or other configuration that is using that Static NAT.
or you can use the CLI to do that with NO prefixing it.
