7200 on only windowXP
May 2nd, 2007
i have window XP only its not showing the SP1 or 2. I tried to install the 7200 simulator which use dynamips and dynagen but it is not working. When i tried to run that simulator its pop up the dos scree and ask for press any key to continue and when i pressed the key screeen just disappeared. so how can i make it up and running?
faisal.saleem Wed, 05/02/2007 - 06:11
Try all these...
hxxp://dynagen.org/tutorial.htm
hxxp://www.sadikhov.com/forum/index.php?showtopic=73869
hxxp://www.blindhog.net/cisco-dynagen-dynamips-basic-t1-configuration/
hxxp://classroom.internetworkexpert.com/p27794135/
(i also capture this whole internetwork tutorial and upload it at ==> hxxp://rapidshare.com/files/28732083/Internetwork_expert_dynamips_tutorial.rar.html
so u no need to still watch it online)
For linux users ==>hxxp://www.blindhog.net/cisco-dynamips-and-dynagen-install-on-linux/
official forum==>hxxp://hacki.at/7200emu/index.php
royalblues Wed, 05/02/2007 - 10:00
  • Green, 3000 points or more
What is the error you are getting
Narayan
dangal.43 Wed, 05/02/2007 - 12:09
its just pop up the DOS screen and then message "press any key to continue..."
then after few time DOS screen appear with dump character.
CSCO10892433 Wed, 05/02/2007 - 19:21
  • Silver, 250 points or more
Hi, Dan
I have encountered the same problem before. In my case, it was WinXP's problem. After I upgraded to SP2, the problem was solved. Check your WinXP version, if it is SP1, upgreade it to SP2. There is a big chance you can fix your problem, otherwise, you can go to the following site and seeking for helps.
http://hacki.at/7200emu/
Good Lucks
SSLIN
