4006 - Sytem conversion CatOS to IOS
Answered Question
May 2nd, 2007
I need to upgrade a Catalyst 4006 from CatOS to IOS.
I have some doubt.
Is it possible? Wich are the rquirements? Wich is the procedure? Any issues?
Thanks in advance
Enrico
Correct Answer by mohammedmahmoud about 10 years 3 weeks ago
The Catalyst 4500/4000 Series Supervisor II-Plus, III, IV and V runs Cisco IOS? software only, and does not run Catalyst OS software. While Supervisor 1 and 2 runs only CatOS and can't be converted.
HTH, please rate if it does help,
Mohammed Mahmoud.
Correct Answer by ankbhasi about 10 years 3 weeks ago
Hi Enrico,
You cannot convert from CATOS to IOS on Cat4006.
SUP 1 & Sup 2 on Cat4000 switch only supports CATOS and NOT IOS.
Ankur
*PLs rate all helpfull post
Overall Rating: 5 (2 ratings)
Correct Answer
ankbhasi Wed, 05/02/2007 - 06:00
  • Cisco Employee,
Hi Enrico,
Ankur
Correct Answer
mohammedmahmoud Wed, 05/02/2007 - 06:12
  • Green, 3000 points or more
Mohammed Mahmoud.
