ContactInactiveException in HTTP trigger application
May 2nd, 2007
I have an application that is invoked via a http trigger, and that automatically dials a series of outside calls.
The script takes usually several hours to finish.
The script ran fine on a CRS 3.1 server, but after we built a new CRS 4.0 server and set up the applications again, the script fails to end properly, with a ContactInactiveException.
This is the log for that exception:
142562: Apr 24 16:22:52.396 ART %MIVR-SS_TEL-7-UNK:CallID:59517000000015, GenericMsgHandler: exception while read/peek MsgQ.: Exception=com.cisco.contact.ContactInactiveException: Contact id: 595, Channel id: 1, Call dropped
142563: Apr 24 16:22:52.396 ART %MIVR-SS_TEL-7-EXCEPTION:com.cisco.contact.ContactInactiveException: Contact id: 595, Channel id: 1, Call dropped
142570: Apr 24 16:22:52.411 ART %MIVR-ALARM_MGR-3-UNK:MIVR alarmwriter queue is full some alarms will be dropped
142571: Apr 24 16:22:52.411 ART %MIVR-APP_MGR-3-TASK_ABORTED:Application task aborted: Application=App[name=Llamadas_Salientes_01,type=Cisco Script Application,id=11,desc=Llamadas_Salientes_01,enabled=true,max=10,valid=true,optional=[script=absa_llamador_v3.2.aef,cfgVars=[Lcom.cisco.wfapi.util.WFNameValuePair;@157457b]],Application Trigger=ContactApplicationTrigger[time=1177434388396,contact=HttpContact[id=10,type=Cisco Http Contact,implId=null,active=true,state=CONTACT_RECEIVED,inbound=true,handled=false,locale=es_CO,aborting=false,app=App[name=Llamadas_Salientes_01,type=Cisco Script Application,id=11,desc=Llamadas_Salientes_01,enabled=true,max=10,valid=true,optional=[script=absa_llamador_v3.2.aef,cfgVars=[Lcom.cisco.wfapi.util.WFNameValuePair;@157457b]],task=17000000015,session=null,seqNum=-1,time=1177434388396,[email protected]]],Task id=17000000015,Task Class=class com.cisco.app.impl.WFWorkflowAppDebugTaskWrapper,Exception=com.cisco.app.impl.ContactInactiveException: Contact id: 595, Contact terminated remotely
142572: Apr 24 16:22:52.411 ART %MIVR-APP_MGR-3-EXCEPTION:com.cisco.app.impl.ContactInactiveException: Contact id: 595, Contact terminated remotely
142573: Apr 24 16:22:52.411 ART %MIVR-APP_MGR-3-EXCEPTION: at com.cisco.app.impl.ContactInactiveInterruption.getException(ApplicationManagerImpl.java:7973)
142597: Apr 24 16:22:52.411 ART %MIVR-APP_MGR-6-ABORTING_CONTACT:Aborting contact: Application=Llamadas_Salientes_01,Task id=17000000015,Contact id=10,Contact implementation id=null,Contact Class=com.cisco.http.HttpContact,Contact Type=Cisco Http Contact,Exception=com.cisco.app.impl.ContactInactiveException: Contact id: 595, Contact terminated remotely
142598: Apr 24 16:22:52.411 ART %MIVR-APP_MGR-6-EXCEPTION:com.cisco.app.impl.ContactInactiveException: Contact id: 595, Contact terminated remotely
142599: Apr 24 16:22:52.411 ART %MIVR-APP_MGR-6-EXCEPTION: at com.cisco.app.impl.ContactInactiveInterruption.getException(ApplicationManagerImpl.java:7973)
142621: Apr 24 16:22:52.411 ART %MIVR-APP_MGR-6-EXCEPTION: at java.lang.Thread.run(Thread.java:534)
My guess is that the trigger times out before the scr?pt ends...
Should I increase the Idle timeout parameter in the HTTP trigger configuration? Or is there another parameter to consider?
Ariel
gmarogi Tue, 05/08/2007 - 08:35
  • Bronze, 100 points or more
Are you using different codecs?
Hi Ariel,
We have a new script where we are triggering from an HTTP trigger and trying to make outbound calls. We too are using CRS 4.0 ((4)_Build140) and if the person who is called hangs up during most points in the script it will terminate despite us handling the ContactInactiveException. Did you get resolution to your problem?
