ASA and Cisco VPN question
Answered Question
May 2nd, 2007
I am having an issue on a new ASA. I am able to connect to the customer?s network using the Cisco VPN client, but I am not able to PING or access anything on the customers network. What needs to be done to fix this???
There is a route on the customer?s router pointing back to the firewall for the IP range you get when you VPN in?
Chris
Correct Answer by acomiskey about 9 years 11 months ago
Thanks, please rate.
No, it is needed for pix as well. ASA 7.2, the command is "crypto isakmp nat-traversal".
It is necessary if vpn client is connecting behind nat. Allows ipsec to be encapsulated in udp port 4500. The transport tab I mentioned is in the connection entry properties, if you click modify. You will see enable transparent tunneling over udp.
try adding to ASA...this is disabled by default
Overall Rating: 5 (2 ratings)
acomiskey Wed, 05/02/2007 - 06:56
  • Green, 3000 points or more
The config of the ASA would help. Without the config we can only guess, usually this is a nat-t issue. Make sure in vpn client config on the transport tab that you have "Enable transparent tunneling" checked.
Correct Answer
acomiskey Wed, 05/02/2007 - 07:18
chris.damore Wed, 05/02/2007 - 07:32
That fixed it! You are the man!!
Is this something new you have to do for the ASA?
Thanks again,
Chris
Correct Answer
acomiskey Wed, 05/02/2007 - 07:38
chris.damore Wed, 05/02/2007 - 07:41
I understand now...
Thank you very much for all of your help with this!!!!
