peterledwidge Wed, 05/02/2007 - 07:02
config t
int serial x
load-interval 30
Default is 300 seconds or 5 mins
Using show int serial x you should be able to see load on the interface at 30 second intevals.
Check load i.e 255/255 is using 100% 125/255 is 50% utilization.
BTW
A tool you could look at using is mrtg - see www.mrtg.org
The load interval option sould be quickest for you.
darkbeatz Wed, 05/02/2007 - 07:19
thanks for the reply. i was hoping to see if I could see what sort of traffic is actually passing through or at least what protocols are chewing up the bandwidth
yjdabear Wed, 05/02/2007 - 07:48
If supported by your gateway software and hardware, you can enable NetFlow cache ("ip route-cache flow") on ther serial interface, with or without exporting it to a NetFlow collector:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800ca6cc.html
This will let you get a quick snapshot of the through traffic with "show ip cache flow" on the gateway, or a longer term view on the NetFlow collector/reporting tool.
