Line has invalid autocommand " ppp negotiate"
May 2nd, 2007
Hi all,
i am trying to deploy radius authentication on my switches.
aaa authentication login default group radius local
aaa authorization exec default group radius local
I think that these two command is everythink what i need for radius authentication and authorization.
But when i try to login i get error message:
Please could you help me? I try to use command
line vty 0 15
no autocommand ppp negotiate
but with no success.
Please i need you urgent help.
Thanks a lot
Tomas
Jagdeep Gambhir Wed, 05/02/2007 - 09:43
  • Red, 2250 points or more
Tomas,
This message is seen when switch has exec authorizaton configured,and the RADIUS server has settings for a PPP connection. Therefore the switch is attempting to start PPP as it was asked to do by the RADIUS server. PPP can't be started on a telnet connection, so it fails and disconnects.
Suggestion : Either remove exec authorization or remove the Service-Type=Framed and/or
Framed-Protocol=PPP attributes from the RADIUS profile.
I hope the information would help resolving your query.
tomas.backo Wed, 05/02/2007 - 23:13
Hi igambhir,
thank very much, i remove service-type and framed-protocol from radius, and that error message doesn't appear again.
But new problem arised for me :)
Authorization failed
But i don't know why?
I have command
and i expect that when i am able to authenticate on radius i will be able to authorized also.
It is needed to set somethning on microsoft radius server?
Thanks in advance
Tomas
Jagdeep Gambhir Thu, 05/03/2007 - 05:43
Make service type = Login
If still error is there , get debugs
debug authorization
debug radius
band2headboy Tue, 10/05/2010 - 11:39
If you are using IAS on Windows 2k3 you can apply the "Request must contain the message authenticator attribute" check box to your switch profile!
