May 2nd, 2007
hi all can anyone direct me to where I can get information as well as data for my company to switch over from PSTN to Voip ?? I am needing things like what equipment how much bandwidth cost of etc type of reading.
Thank You
Brandon Buffin Wed, 05/02/2007 - 07:16
The links on the following page are a good place to start for an overview of the Cisco solution.
You will also find a lot of information if you search the internet for "voip" and "IP telephony". At some point you will likely need to engage a partner to consider the specifics needed for your business.
Hope this helps. If so, please rate the post.
