WLSE 2.11
May 2nd, 2007
Hi everyone: I'm trying to upgrade the ios and I'm setting a repository as intructed on the manual. The problem I'm having is that when I do "repository list remote or repository remote detial or page" its asked me for a username and password (which is correct) after typing the username/password, it gives me the following error: "Directory listing of URL: unlink: No such file or directory
Directory listing not allowed."
The ftp source is my pc and I have set FTP on it and I can FTP to it with no problems, (I have tested from another pc using IE and it works fine) but not from the WLSE appliance itself. I'm also running the backup and restore utility from the WLSE using HTTP (my pc is where the backup image is stored) and that is working fine, but I do not know why the repository is not working for me... Any ideas? thank you very much!
jreekers Wed, 05/02/2007 - 09:33
If you're upgrading from version 2.7, 2.7.1, 2.9 or 2.9.1a, did you install the "pre-upgrade patch", related to bug CSCsa93623?
Trending Topics - Security & Network
