ping unreachable from outside to F0/0
May 2nd, 2007
It's a 3700 router. I am wondering, icmp ping could not reach to F0/0 from outside. i can ping and telnet to s0/0.
int s0/0 -
int f0/0 -
I do an extended ping within this router. source s0/0 and target f0/0. No Response.
No Access-list configured.
It was working for many years and I can telnet to the F0/0 before. Right now, no response either ping or telnet.
any idea?
royalblues Wed, 05/02/2007 - 07:46
Do you have a route for the Fa subnet from the other end router?
Gerard Gacusan Wed, 05/02/2007 - 07:49
ip route
This is a live network, i'm just giving here a fake ip address but the setup is the same to narrow down the issue.
I can telnet to the s0/0 from outside. All interfaces are UP/UP.
kcgeorge1218 Wed, 05/02/2007 - 07:55
Can u PING the 172.x.x.x interface (Gateway, I guess) while on the 172.x.x.x LAN/VLAN
Gerard Gacusan Wed, 05/02/2007 - 08:01
i think there's something wrong with my ISP. They probably remove routes on their end. I can't route from F0/0 to anywhere (ex.
Gerard Gacusan Wed, 05/02/2007 - 08:08
yes i can ping from host(LAN) to the gateway F0/0.
weird thing, the host could route to outside and internet is fine.
I do an extended ping:
target -
source - FO/0
result - no response
target -
source - s0/0
result - successful
Gerard Gacusan Wed, 05/02/2007 - 09:13
I reload the router and works now ...No problem on the configuration.
One thing that i didn't do is clear ip route *. But, reloading is much helpful. Strange problem.
mohammedmahmoud Wed, 05/02/2007 - 09:19
Please make sure that you've configured keepalive under the ethernet interface.
Mohammed Mahmoud.
