ASDM and AIP-SSM
jkeddington_2
I have upgraded the AIP to version 6.0 and I should be able to now launch the IPS module in ASDM, but instead I get an error - unable to connect too sensor. I can access the sensor just fine from IE.
6 Replies 6
acomiskey
Level 10
Level 10
Are you trying the correct ip address? Does the ASA have a route to this ip?
More info: The person sitting next too me has not issues. From ASDM he can launch IPS inside ASDM, so I know it does work. Yes I the correct IP address is being displayed in ASDM. No there is not a route in the ASA because the IP address of the AIP-SSM is in the same subnet as the inside interface of the ASA. Yes I do have a cable connecting the AIP-SSM management port to an internal switch.
Is the ASA an "allowed host"?
service host
network settings
access-list /32
Great question. Actually I have it open for the entire class B network range. Someone sitting right next too me can get it too work but I can't.
The guy next to you has no problem connecting through ASDM to the same ASA you are trying or a completely different ASA?
edit: Also is ssl enabled on the sensor?
service web-server
enable-tls
port 443
Yes it is. Just to make things a little easier here is my config for the AIP-SSM:
! Current configuration last modified Wed May 02 12:35:15 2007
! Version 6.0(1)
! Host:
! Realm Keys key1.0
! Signature Definition:
! Signature Update S274.0 2007-03-01
! Virus Update V1.2 2005-11-24
service interface
exit
service authentication
exit
service event-action-rules rules0
overrides deny-packet-inline
override-item-status Enabled
risk-rating-range 90-100
exit
exit
service host
network-settings
host-ip x.x.18.253/27,x.x.18.225
host-name sensor
telnet-option disabled
access-list x.x.0.0/16
exit
time-zone-settings
offset -420
standard-time-zone-name GMT-07:00
exit
summertime-option recurring
offset 60
summertime-zone-name GMT-07:00
start-summertime
month march
week-of-month second
day-of-week sunday
time-of-day 02:00:00
exit
end-summertime
month november
week-of-month first
day-of-week sunday
exit
exit
exit
service logger
exit
service network-access
exit
service notification
exit
service signature-definition sig0
exit
service ssh-known-hosts
exit
service trusted-certificates
exit
service web-server
enable-tls true
port 443
exit
service anomaly-detection ad0
exit
service external-product-interface
exit
service analysis-engine
virtual-sensor vs0
physical-interface GigabitEthernet0/1
