05-02-2007 11:00 AM - edited 03-09-2019 05:54 PM
Any time i try to connect with MACOS 10.4.8 with Web browser Safari and try to establish a SSL tunnel i got the following message : "The installer cant startup Cisco SSI/VPN client". Maybe because it cant download from the VPN3000. Exists any specific SSL client for this type of OS to work with VPN3000? Is it supported by Cisco?
05-02-2007 05:35 PM
The SVC requires Windows 2000 or Windows XP on the remote computer.
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_7_2/conf_gd/vpn/svc.htm#wp1039855
A new SSL VPN client is coming out called "AnyConnect". This will operate in ASA 8.0 code expected to release soon.
It offers:
Support for Mac and Linux platforms
Support for 32-bit Windows 2K, XP, and Vista
- 64-bit platforms to follow
64-bit Vista and 64-bit XP will only be supported with AnyConnect and the ASA
HTH,
Chuck
05-03-2007 04:25 AM
So, no way to use SVC on MAC/Linux with VPN3000.
Is it correct?
05-03-2007 08:10 AM
Yep. No way on the 3K. You'll have to have an ASA/PIX and you will need the 8.0 code on the box.
