Enabling Multicast on mixed Layer 3 / Layer 2 switches
May 2nd, 2007
I'm trying to switch my Music on Hold streams from Unicast to Multicast, and am hitting some snag when enabling multicast on the network. The core of the network consists of 4 6500 switches, 2 as core, 2 for servers. All are Native mode with SUP720s. The 2 core switches are then connected to 3560 closet switches, which just run at Layer 2.
On the 6500s, I've set "ip multicast-routing", and also "ip pim sparse-dense-mode" on all Layer 3 interfaces. I've also done all the required steps in CallManager, and can see the CallManager join the group:
Server-6500-1>sh ip igmp group 239.1.1.1
IGMP Connected Group Membership
Group Address Interface Uptime Expires Last Reporter
239.1.1.1 Vlan2 12:52:51 00:02:15 10.1.2.170
Also, when I put a phone on hold, I see it join the group as well:
Core-6500-1>sh ip igmp group 239.1.1.1
239.1.1.1 Vlan20 00:05:02 00:02:34 10.1.20.11
And the outgoing interface gets updated both on the server and core switch:
Server-6500-1>sh ip mroute 239.1.1.1
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report, Z - Multicast Tunnel
Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.1.1.1), 14:00:02/00:03:28, RP 10.1.3.12, flags: SJCF
Incoming interface: Vlan3, RPF nbr 10.1.3.12, Partial-SC
Outgoing interface list:
Vlan255, Forward/Sparse-Dense, 00:00:01/00:03:28, H
Vlan251, Forward/Sparse-Dense, 13:11:57/00:02:45, H
(10.1.2.170, 239.1.1.1), 13:11:57/00:02:52, flags: FT
Incoming interface: Vlan251, RPF nbr 0.0.0.0, RPF-MFD
Vlan2, Forward/Sparse-Dense, 00:00:01/00:03:28, H
Core-6500-1>sh ip mroute 239.1.1.1
(*, 239.1.1.1), 00:36:18/00:02:47, RP 10.1.3.12, flags: SJC
Incoming interface: Vlan255, RPF nbr 10.1.4.13, Partial-SC
Vlan20, Forward/Sparse-Dense, 00:00:12/00:02:47, H
However, I get silence on the phone (not even the 3 quick beeps), and the layer 2 switch shows no multicast packets received:
3560-20>sh int fa0/22
FastEthernet0/22 is up, line protocol is up (connected)
5 minute input rate 2000 bits/sec, 3 packets/sec
5 minute output rate 65000 bits/sec, 80 packets/sec
451542 packets input, 116439487 bytes, 0 no buffer
Received 5185 broadcasts (0 multicast)
Could there be a step I missed, or is it a problem with the CallManager MoH stream?
