Problems with QOS on ASA 5505
May 2nd, 2007
I am setting up asa 5505s for our home users. I setup everything and its working fine until I setup Qos. It will work for a couple of days but if you reboot the asa the easy vpn is disabled and it gives me some "disable aaa authentication" error when I try to re-enable it. I have to re-enter the "no aaa authentication" commands so I can enable the VPN again. Here are the commands I am using for this. Any ideas on why this is happening. (noobish)
http 192.168.18.0 255.255.255.0 inside
http 10.155.1.0 255.255.255.0 inside
no dhcpd enable inside
interface vlan1
ip address 192.168.18.1 255.255.255.0
dhcpd address 192.168.18.2-192.168.18.12 inside
dhcpd enable inside
no aaa authentication listener http inside port www redirect
no aaa authentication listener https inside port 1443 redirect
no nat (inside) 0 access-list _vpnc_nwp_acl
vpnclient server ***.***.***.***
vpnclient mode network
vpnclient vpngroup ****** password ***********
vpnclient username ********* password *************
vpnclient enable
access-list 102 remark : Nortel Voice over IP Ports
access-list 102 extended permit udp any any eq 5000
access-list 102 extended permit udp any any eq 7000
access-list 102 extended permit udp any any range 28000 28255
access-list 103 remark : Nortel Server VoIP Packets
priority-queue inside
priority-queue outside
class-map Nortel_SERVER
match access-list 103
class-map Nortel_UDPPORTS
match access-list 102
class-map Nortel_VOIPPHONES
match dscp ef
policy-map VOIP_POLICY
class Nortel_UDPPORTS
priority
class Nortel_SERVER
priority
class Nortel_VOIPPHONES
priority
service-policy VOIP_POLICY interface outside
Overall Rating: 4 (2 ratings)
brianadixon Fri, 05/04/2007 - 04:40
Thanks for the reply.... I get a Forbidden File or Application" when trying to go to that link.
