Connect to a home lab
mohammedmahmoud Wed, 05/02/2007 - 23:11
  • Green, 3000 points or more
The simplest solution is having an internet connection with public IPs to telnet from your work to your house, but you'll need to secure the path.
HTH, please rate if it does help,
Mohammed Mahmoud.
dianewalker Fri, 05/11/2007 - 19:40
Shawn,
If you have a static IP address at home, you can put that static IP address in your router or firewall at work. This way you had a direct line from work to home. However, the disadvantage is if your lab computer has a virus, it would affect the entire network at work.
Thanks.
rmmbminola Tue, 05/29/2007 - 06:11
diane could you give me a config example i could use to set it up on a 2511 router, thanks
cisco steps Sun, 05/13/2007 - 09:27
hi
I would like to do the same. I do not have a static Ip, my WAN ip has not changed for long time. so I am wondering if I can config my 2511 com-serv w/ private LAN ip coming from my smc wireless router. I know I probably need to allow telenet session in my dsl router/ but first need to know how to configure the 2511 .. thanks
I was able to use port forwarding on my router, it has a private IP of 10.0.0.1 and the ethernet on my 2511 is 10.0.0.2. Here is my current setup:
cable modem ---- router [port forwarding,straight through cable] --- 2511 [AUI ethernet transceiver RJ45].
Here is the relevant part of the 2511 config.
interface Ethernet0
ip address 10.0.0.2 255.255.255.0
no ip directed-broadcast
no shutdown
interface Serial0
no ip address
no ip mroute-cache
shutdown
no fair-queue
interface Serial1
no ip address
shutdown
ip classless
no ip http server
ip route 0.0.0.0 0.0.0.0 10.0.0.1
line con 0
exec-timeout 0 0
logging synchronous
transport input none
line 1 16
transport input all
line aux 0
line vty 0 4
password 'insert password here'
login
cisco steps Sat, 05/19/2007 - 09:27
Thanks a lot and as usual , I will try it one I am need my lab and left you know .
