turning on AAA between new PIX 535 and ACS srvr
dgalati000
Can't find a command ref for a new Pix (vers 7.2(1)13 )) for this command >>
ip tacacs source interface <<. Also, can't enter this command into the Pix.
romason
You specify the interface in the following manner:
1. Define the server group and the protocol
2. Then specify the "source interface" and the host:
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_7_2/conf_gd/general/aaa.htm#wp1089730
hostname(config)# aaa-server AuthInbound protocol tacacs+
hostname(config-aaa-server-group)# max-failed-attempts 2
hostname(config-aaa-server-group)# reactivation-mode depletion deadtime 20
hostname(config-aaa-server-group)# exit
hostname(config)# aaa-server AuthInbound (inside) host 10.1.1.1
hostname(config-aaa-server-host)# key TACPlusUauthKey
hostname(config-aaa-server-host)# exit
HTH,
Chuck
