can't get past my Cable modem to DNS servers
Answered Question
May 2nd, 2007
Hello all I have googled several items regarding this problem and have tried about all of them to no avail.
Setup-
1 cable modem (lynksys wcg200)No DHCP
1 cisco router 4500
1 linux box
I have the linux box connected to the cable modem with static IP all good here.
I have the cisco router connected to the cable modem throught FastEthernet 0 up up
I can ping from the router to both cable modem and linux box. WOOT!
Can't ping past the cable modem. :(
Current configuration : 1324 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
no service dhcp
hostname BCBehind
logging queue-limit 100
enable secret xxx
ip subnet-zero
no ip domain-lookup
ip domain-name lookup
ip name-server 24.x.80.36
ip name-server 24.x.176.38
partition flash 3 8 4 4
interface Ethernet0
ip nat inside
media-type 10BaseT
interface Ethernet1
ip address 10.0.1.1 255.255.255.252
media-type 10BaseT
interface Ethernet2
no ip address
shutdown
media-type 10BaseT
interface Ethernet3
no ip address
shutdown
media-type 10BaseT
interface Ethernet4
no ip address
shutdown
media-type 10BaseT
interface Ethernet5
no ip address
shutdown
media-type 10BaseT
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
interface Serial2
no ip address
shutdown
interface Serial3
no ip address
shutdown
interface FastEthernet0
ip address 192.168.0.2 255.255.255.0
ip nat outside
full-duplex
router rip
version 2
network 10.0.0.0
network 192.168.0.0
no auto-summary
ip default-gateway 192.168.0.1
ip classless
ip route 192.168.0.0 255.255.255.0 192.168.0.1
no ip http server
line con 0
line aux 0
line vty 0 4
login
end
Any help is greatly appreciated
Correct Answer by Jon Marshall about 10 years 3 weeks ago
Hi Bruce
Could you add a static default route to your router
"ip route 0.0.0.0 0.0.0.0 192.168.0.1"
I don't believe the router will use your ip default-gateway command when in routing mode.
I assume that your cable modem is Natting all outbound traffic to an Internet routable address.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 05/02/2007 - 21:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Bruce
Jon
bruce.cowan Thu, 05/03/2007 - 07:24
Thanx mate I am now able to ping outside using IPs now to fix the pesky dns issue
