sticky group timer?
May 2nd, 2007
What is the timer in the sticky group do? It is an idle timer or cache timer? I am using source ip based sticky on one of my vserver. there are two reals behind it and only two front end (proxy) web servers that hits it. when I remove one of the real (serverA), all the connection sourced by the two web server goes to the other real(serverB). When I bring back serverA, I don't see any connection going to it. I think that's because the two front end web servers are being "stuck" to serverB. When I view the sticky table, I see the specific group with a timer value that's decreasing. I'm tempted to change the sticky timer to 1 (minute) but am not sure it it's a idle timer or a cache timer.
example config:
sticky 130 netmask timeout 30
vserver backend_App
virtual x.x.x.x
server x
sticky 30 group 130
Syed Iftekhar Ahmed Wed, 05/02/2007 - 23:16
The timeout specifies the period of time that the sticky information is kept in the sticky tables. The sticky timer for a specific entry is reset each time when a new connection matching that entry is opened.
Gilles Dufour Thu, 05/03/2007 - 03:43
sticky source-ip when there is only 2 ip coming in is not a very good solution.
If we are talking http, you should check the possibility to use cookie.
If your servers do not have a cookie that can be used for stickyness, then I would suggest to use the cookie-insert feature of the CSM allowing the CSM to generate is own cookie.
